I have engraved and cut my first test files. No problem with it, pretty simple…
… but the question is that I’m aware of the x/y axis are acting like an ink printer: x sweep and y advance. It doesn’t cut or engrave moving the laser from object to object, sequentially. Don’t know if I’m explaining right… Is there any setting to allow me saving time? Anything I try to cut/engrave delays a lot acting the laser this way…
I use Lightburn, last version. I know it’s a software issue, not a Falcon2 one
Thanks in advance! Greetings from Spain.
It sounds to me like you might be having an issue with using layers in Lightburn and the order of tasks within a Lightburn project, but I’m just guessing here.
If you are dealing with multiples of the same “object” in a single project, you might want to search for info on “Batch Jobs” in Lightburn.
