Hey guys, im kind of lost here, grinding 5 hours straight to fix my problem with the falcon 2. I received it today, when engraving or cutting, it just stops, there is no homecoming, no signals, nothing. I tried everything, pluged it into an other wall, used an other Computer, nothing helps. Then i wrote the Gcode on a SD-Card, and it just worked fine. What could be the problem? Also why is the beep sounds so loud? A neighbour called the house-caretaker not because of smoke from the laser, she called him because of the beeping, she was thinking there is an fire-alarm beeping…
Preciate your help, i really want to create some fantastic stuff !
