I’ve been using the Falcon 2 40W for a couple of days and while it initially worked fine, after the first session there’s no beam when it does the Frame function.
I had a couple of issues with the Lightburn driver - the file on the TScard didn’t let Lightburn find the laser but using ‘Find my laser’ when connected to the Falcon solved that problem. But it was around then that it stopped shining the beam during Frame.
Is there some code I can add that will trigger it again?
