Falcon 2 Pro Homing not working when USB connected (y-axis)
Hello,
I have a new Falcon 2 Pro. The test without having a PC connected was successful
The issue comes up as soon as I connect the machine via USB to PC.
It seems to me that the machine tries to home but doesn’t stop at the home position. From my observation it seems that it tries to go further down when the module arrives in the bottom left position. I think its only the y-axis.
While I have the same issue regardless of lightburn running or not, here the log from lighburn (device settings from the flash drive imported):
ALARM:3
Reset while in motion. Grbl cannot guarantee position. Lost steps are likely. Re-homing is highly recommended.
[MSG:Pgm End]
ok
[MSG:Using cpu_map…esp32-s3]
Grbl 1.1f [‘$’ for help]
ok
ok
ok
ok
ok
ok
ok
ok
[MSG:Pgm End]
ok
ok
ok
ok
ok
ok
ok
ok
ok
ok
[MSG:Pgm End]
It`s an endless loop of [MSG:Pgm End] followed by ok
Tried it with 2 different PCs (Win 11)
Connected via the
LightBurn 1.6.00, built Di 2024-04-30 @ 08:35
I will try to upload a video
edit: Video added:
Can someone see what wrong?
So when it’s not hooded up USB the home works correctly? Did you install the driver that came with the unit? Did you check the settings. Need more info. Screen shots will help as well as posting to the Facebook group.
Thank you for your reply. Without the USB connected the homing does work correctly. I add in this comment a video without connected USB.
In the meantime I performed a firmware update of both the laser and machine:
CV50-LASER-22W-Release_V3_0_5.bin
CV50-Pro-MASTER-Release_V1_0_0.bin
This didn’t make any difference
I tried installing the delivered drivers - not successful. Win11 won’t let me install the Win7 drivers from the flash drive because newer drivers already exists.
The device is recognized as “Serielles USB-Gerät (COM4)” (= Serial USB-Device(COM4))
The homing is working fine as long as the machine is not connected:
When connecting after turning on:
Turn on machine (USB not connected)
Press Home → Homing successfull. No “rumbling”, all normal
Connect USB → “Rumbling” starts
When turning on while connected:
Connect to pc
Turn on → Homing starts → “Rumbling” starts
All this with lightburn closed. => I can only conclude that this is not an issue with LightBurn settings
Really sound like your lightburn settings as wrong some where. Try removing light burn and drivers and start over. Share screenshots of lightburn.
Join the Facebook group for more support.
Probably not in the equation, but if I were you, I’d check all the cable pins - this has a habbit to cause all kind of weird things.
Search on this forum - there are many mentions of this causing various issues.
Just unplug all connectors you have access to, check the pins to ensure none is bent, then gently re-insert the connectors, making extra caution that no pins get bent.
Do this for all connectors you have access to.
It’s an extra step that probably won’t fix your issue, but you never know - plus it’s easy and fast to do.
Might as well put all the chances on your side :smiley:
Thank you for your input.
I deinstalled lightburn. The issue persists.
Here Screenshots of my lightburn settings:
I will try the facebook group too.
Im having the same issue !! did you resolve it ?
Just ran into the same problem after months of use. The only thing I did recently was unplug the air and disable the homing cycle (on start up, and in the $settings,) so that I could laser some powder. Plugging back in the air and re-enabling all homing causes this issue. Unplug USB and everything works great.
Going to re-install
Did anyone get this issue resolved, mine started doing it last night as well.
Pretty sure it’s an issue with a rogue LightBurn setting. You might want to completely uninstall everything, including profiles, and start from scratch. Double-check the $$ machine code settings.
In my case, I don’t know exactly what fixed it, as I did that, and while troubleshooting I noticed excessive resistance on the Y axis. It seems that the bearings get clogged and come close to failure every 30-60 days for me. I clean up with WD-40, then spray a little lithium grease. Also, my Y-axis servo is pretty corroded. Depending on what materials you’re cutting, it could be that you really need to clean things up.
Try moving the gantry by hand. Do you feel any skipping? Both axis feel the same, and butter-smooth?
I am having the exact same problem. I have the falcon2 connected to my computer with the usb cord. I am also using lightburn. For the last 3 days it has worked fine (unit is 3 days old). Now when I try and set up a file and then check the frame the laser module just dives to the the lower left hand corner and jams itself into that position. I can use lightburn to move it around the screen and I can also use the home button on lightburn and it works. But if I attempt to frame any art work on the screen it gives me Error 3 (Rehoming required) which does not work. Any fix yet from Creality??
For me it was a loose connection of the usb cable connector. I removed the black plate on the inside, where the connection from outside comes in and tried to better connect it . Either it was the loose connection alone or the signal gets distorted with the very poorly done isolation by the power connection right below.
It`s working for now when I’m carefull.
I wish I sent the machine back to be replaced because this is really poor manufacturing but it was too much of a hassle to disassemble everything again at the time
Just wanted to drop a note that I was having this issue every cut. I suspect it’s a problem with the native USB driver in windows. As others have said it isn’t possible to use the drivers provided on the usb stick in win 11. However, I was able to resolve somewhat - if I unplug the camera usb from the computer it works fine! So something possible with two different connections on the same computer.
I turn on the device, take my photos, unplug the camera, then hit home on the device. If the camera is plugged in then it immediately grinds into the lower left corner and won’t stop.
I dont use lightburn, just the simple falcon software, as my prints aren’t too complex.
