my k2 plus stopt working and gives a faultcode 2355?
anybody know this problem?
any luck with this just happend to me last night ?
I was getting the same error. It seemed like it started once I updated to the latest firmware and started using Creality Slicer 6.0. Since then it’s changed to XS2353.
The only change I’ve made since then is swapping in a .60mm nozzle.
I thought rolling both back would help, but that proved to be no success. I even did factory resets, under each firmware, cleaned all the rods and screws, applied new lubricant and cleaned to photo sensors at the base of the printer. All with no luck.
It completes the bed leveling, lays down the purge line and as soon as it returns the head to the middle to start printing it errors.
I’m starting a case with Creality support to see if we can fix the issue. I’ll update this thread when I find out the fix.
ok thanks for the info Ive also put in a service ticket but have not heard back fom Creaity yet.
I found my problem its the power cable that goes to the nozzle. After a while of printing the cable bends to much to far and probably get a break in the cable.
I dismanteld the cable and assembelt it the Other way arround. Nozzle connector in the side board and side board in the nozzle.
Thats how i figured it out.
What do you mean by this? When you say nozzle cables, how do you swap these cables around? Are you referring to the power cable that connect to the entire print head?
I have the same issue. First i had problems with bed leveling, the z-axis didnt stop and the hotend got some pressure. I changed the straing gauge. After that the bed levling works fine but by printing, the same error 2355 appears. I ordered a new hotend kit but after swapping it, the failure still exist.
So i have to keep looking what could be my next try. I think its a board.
Its a shame for creality. Opened my ticket allready on 7.01 with all informations they needed, and they replied with some standard wiki solutions… even with a reminder that i need some further assitance, i got a wiki solution answer again
terrible support…
Hi, any update on this issue? I’m getting XS2353 also. On standard 0.4 nozzle and standard Creality print profile of 0.20, which have max speed of 300 mm/s for the outside perimeter. If I reduce that max speed down to 250, it works fine. 300 mm/s is way lower than the advertised max speed of 600 already. and yet it cannot handle it properly.
