Filament Guide
Needed these for my model “CFS as a spoolholder” as well as other replacement needs including for my CFS, or they can be used other application. 3D Printer Files | 3MF File | Filament Guide | Creality Cloud
See the CFS as spoolholder model at → 3D Printer Files | 3MF File | CFS as Spool Holder e.g. TPU or Abrasive-Direct to Extruder | Creality Cloud
The guide is intended to assist in maintaining a steady and efficient flow of filament in your 3D printer setup, perfect for desktop printers to avoid filament jams.
These do require a Pneumatic Connector PC4-M10. Just attach to the bottom of the guide and then attach to the applicable PTFE tube ensuring it fits securely all the way in the guide.See photograph attached.
I used some from Amazon “PC4-M10” (6mm threads length—but length of threads is not too important)
NOTE:!!! Be sure to clean out the hole the filament passes through as there are no supports so some filament crosses across the hole during printing.
