Filament not sticking to bed
hi it seems the filament is getting dragged across plate and not sticking any advice
Clean the bed with dishwashing liquid and isopropyl alcohol (IPA) then learn how to do z-offset/babystep. Often the nozzle is just a little too far from the bed, when I say little I mean 0.05/0.1mm, the thickness of a hair. It takes a little practice to get this homed in Worse comes to worse, gluestick, you shouldn’t need it but if I am doing an overnight or multiday print I will use it just to be sure the print doesn’t fail.
thanks for help will try it
If it layers well but doesn’t stick, it’s the pad that’s at fault. As colleague says above, clean it with isopropyl alcohol and if that doesn’t help, add some 3D LACK spray and you won’t even be able to tear it off. Just practice.
