News Information how to create a new filament in Creality print and parameter for a generic pa-gf filament
Hey there, you can choose your Creality 3D printer model within the software, In the filament section of the software, you can select “General Filament” as a starting point. Since Creality Print may not directly support all generic filaments, you will need to manually input the parameters for PA-GF. Based on the parameter guide provided by Creality, you can set the following parameters as a reference:
*Nozzle Temperature (℃): 230-260 (recommended 250℃)
*Heatbed Temperature (℃): 80-90 (recommended 80℃)
*Printing Speed (mm/s): 40-80 (recommended 50mm/s)
*Environmental Temperature (℃): 60-80℃
Find the option to save or create a new filament profile within the software. This is usually located at the bottom or side panel of the filament settings. Once saved, you will be able to select this custom PA-GF filament profile for future prints.
Additionally, since Creality Print software may not directly support importing .cxprofile files, you may need to manually enter the parameters rather than setting them through importing a configuration file.
Thanks, can you attach some screen shot of create new filament in filament section? I’ve some difficulties! Thanks
