Hello everyone,
I’m having an issue with my Creality Hi Combo (CFS) and I’m currently stuck.
A piece of filament is jammed inside the CFS buffer.
At this point:
The extruder does not pull the filament
The printer cannot unload or retract the filament
The filament is physically stuck inside the buffer, not in the hotend
During unload, the spool sometimes jumps or doesn’t rotate properly
Cutting the filament from outside does not help
The filament is not reaching the extruder anymore, and it’s also not retracting back into the CFS. It seems completely stuck inside the buffer mechanism.
Before opening or disassembling the buffer, I wanted to ask:
Is there any way to release or push the filament without opening the CFS buffer?
Has anyone experienced the same issue on Hi Combo?
Is this a known problem with the buffer or hub outlet sensor?
Thank you in advance.
