File list on ender
I’ve owned a ender 3 V3 SE for about a year and have printed plenty.
Whenever I went to print the file would be at the top of the list, all of a sudden this file may appear anywhere in the list sometimes second from the bottom etc. I’ve checked the layout in windows and the most trecent file is at the top.
Does anyone know where there is a setting for this?
Hello Cromwell,
What version of Creality Print are you using ?
Have you recently changed it ?
If you have changed to a newer version, I would suspect that to be the fault.
Cheers.
P.S. With my V3SE I use Orca; Creality Print is always buggy.
Hi Thankyou for your response. I’m using 6.1.0.2041. Not sure when I last updated maybe a month ago and cant really say when this started happening.
I did suspect that CP was probably responsible and you’re right creality is really buggy. But I keep hoping they’ll get it right. At the moment I cant put one object on top of another, it either bounces back to the deck or disappeares altogether.
I will try another slicer see if that solves the problem.
Thank you for your help.
Hello Cromwell,
I Hope you find the solution with trying another slicer.
Cheers.
