It goes directly on the table after Extrusion, does not go to clean the nozzle or on lever
Is the right printer selected in the right corner in the slicer ? Some 3fm files change the printer profile.
I find out that sometimes goes directly on the table , sometimes goes to clean the nozzle, the profile and filament is the same… what is the criteria to do so ? If go to clean the nozzle then poop came out normaly, if directly then the poop is in the head place… what is the critera to do so ?
Are the prints ok ?
Before probing it going to wipe the nozzle. And when it probe and it a abnormal probe it also wipe again the nozzle.
Is it really a normal poop ? When its only a little it can be a partial nozzle blockage. But if the prints are ok then that can be it.
Then maybe the extruder dont know where he is. And think that he is above the poop hole.
The only error you get is the belt tension, i dont know if that can have so big influence on the coordinates for the extruder. ( Have taken me a hour to get away the error with the manual belt tension screws )
It can also be the kabel on top of the extruder.
just thinking out loud. could be a lot more. but have learned to always clean up the most obvious mess before looking further (belt tension) but can you send a video of what you mean.
maybe some one else here has a idea what to do against a wild pooper.
Like I said there are two scenarios before print…
extudion filament ends:
1.start directly to print, poop goes in the hole betwen extrudor (there is a lid)
2.clean nozzle , poop fall out corectly
in first scenario the print is not ok, prints … and when the Z is enought hight then poop comes out but extrudor beetween prints hops out and lift extrudor and then the print is not ok
in second scenario is all ok
there must be some logical setting when clean nozzle ’
I have just recievd my K2 plus and during the setup i updated the printer over wifi and all worked really well, im at just over 60 hours of printing atm so not a lot at all but have not had any issues with this firmware.
