Firmware 4.2.7 bltouch z-axis
hi i had the 4.2.2 but it burned, so i orderd a new one
4.2.7.
i put the firmware on it, but not from the website, because that one does not work.
but when i move the x y z axis, i have to confirm movement with the enter button.
i am almost positive, you just turned the button to change the x, and it would automatic go.
is this know? and can i change it, that it goes direktly.
thank you
Did you upgrade the display firmware to the save version as the firmware on the new control board.
Bill
I upgraded the board not the display.
How do i upgrade the display.
And it worked before on the display
I only had the 4.2.2. Instead of 4.2.7
Let me know thank you
I also took an other version.
The version from the website dit not work
So i do not know if i have the save version
But where can i get that version
Ender-3 V2 Firmware Update - Current Firmware from Creality (youtube.com)
updating i dit.
so the only file i can find on the website is
Ender-3 V2-Marlin-2.0.1-HW-4.2.7-mainboard-V1.1.2-compatible with BLTouch and filament detection
but that one is not working.
so why is that not working on my machine? i have the 4.2.7 arm st chipset.
and remember the only thing i want is dat the z ax, goes when i turn the knop.
if i am not mistaken that is what he did before with the 4.2.2.
i also find it strange you have to set the z possition and then confirm, if you set it to far.
it will go in to your head bed.
also remember, the printer is working fine, is set it correctly but if this is possible what i say.
i want to fix that.
another question, yesterday i calibrated the the printer
and i set the z ax offset to -1.00
now i turn it on it says 0.00
doesnt it has to say -1.00 again?
he thxs i got it.
i took an other file, i think even older, but from the official website
that does what i wanted, and now looks the same as what i had on the other board.
now only check if it will keep the z ax settings.
and never knew there is a reader in the display, but did not update dat because there is no file for that i think.
for now thank you.
