Hi all new here , trying to print flexible pla having a little trouble I was wandering if there is a place to download slicer files to make it easier as a starting point cheerd… the tpu settings aren’t much help ive tried to copy a few set up but not much luck
Hey,you can consider downloading and installing a slicer software that has good support for flexible filament such as Cura, PrusaSlicer, and Simplify3D, and look for pre-configured profiles within your slicer software. Many slicers come with profiles for different filament, including flexible PLA filament and TPU filament. These can be a good starting point.
Hello @Jarmin_Leonardi …! ![]()
What printer are you using and what kind of problems…?
I don’t see a profile for flex PLA but try slowing the speeds down quite a bit (60%) to start and disable retraction and rafts. Nozzle 230C / Build plate 60C.
Work on some small parts first..
I had some issues when i started printing with pla flex… I could make it work. Change the settings of the filament in creality print. Use Hp TPU and change temperature of the nozzle 225 and volumetric flow rate/speed i place it in 2… it depends on the brand you are using…. so far it is printing great… I´ll try with 3 as it is not tpu and i’ll try it with 5 or 6 as well just to be sure wich is the best settings/speed. with the currecnt settings the only inconvenience i found was the time it takes to print.
