Fluidd interface with blank screen
Hello everyone. I have the following problem: after updating to firmware v1.1.060, I can no longer access the fluidd (IP:4408) interface; all I see is a white screen. I have tried the following browsers: MS Edge, Google Chrome, and Firefox. Switching back to v1.1.050 did not help either. The printer is otherwise accessible via the slicer and also prints. Can anyone here help me? Should I try older firmware versions?
I also have 1.1.0.60, but Fluidd works fine for me. Check the browser console log, maybe that gives more info.
Have you tried doing a factory reset? i have 1.1.0.60 installed on my printer and no issues regarding fluid. Just want to make sure you have double checked your IP has not changed on your Hi? If the IP is correct, i would try a factory reset and hopefully that sorts out the issue.
Thank you for your suggested solutions. The problem was solved by resetting to factory settings. Everything is working again now. Unfortunately, I now have to set up my Knomi again, as the configuration files have been overwritten. Thanks again and happy holidays.
