hello, I just bought the CFS for the K2SE. As a test print, I tried to print Chillet from Palworld (several models, including this https://www.printables.com/model/774161-chillet-mmu and this https://www.printables.com/model/747279-low-poly-chillet and this https://www.printables.com/model/1191408-chillet-multi-material-remix ).
The issue is that every single model I have tried so far has an absolutely unacceptable material to waste ratio. I’m aware that multi-color printing is not exactly efficient, but 760g - 860g of estimated waste for a 26g figurine seems way over the top. Is that a configuration issue, software bug, display bug, firmware bug?
I’m using Creality Print 7.2.1.5476 Release running on Fedora. Calculated flush volume multiplier is 1.3. The unreasonable waste comes from flush volume, not tower. “Flush into Object’s infill” has no effect on calculated waste.
thanks
