FR2849 – Filament Completely Stuck Between Extruder and CFS
I have a Creality Hi Combo and I’m receiving the FR2849 error: “Filament cannot be returned to the CFS hub.”
The filament is completely stuck inside the system. It cannot exit the hotend/extruder, and the CFS cannot retract it. The extruder makes a repeated clicking noise when it tries to move the filament.
There is no accessible place where I can cut the filament, and I also cannot remove the PTFE tubes because the filament is trapped inside them. I checked the buffer and cannot see any blockage there. The filament is visible along the entire path between the extruder and the CFS, but it cannot move forward or backward.
Has anyone experienced this problem? How can I safely release the filament without damaging the extruder, PTFE tubes, or CFS?
One step at a time.
First, use a tool such as a small screwdriver to push down the black ring around the Bowden tube on top of the print head. The tube will retract over the filament.
Next, snip the filament disconnecting the CFS and the print head.
Then follow Creality’s tutorial to disassemble the extruder to clear the jam. https://youtu.be/jWnVZ1nqpPI?si=2t0ODEb50xhnyqd_
Next follow this video to clear the CFS jam. https://youtu.be/SnhlTT5fVtM?si=_luLJCo4bPYI6drJ
Be patient and take it step by step.
OH! one thing I learned: when you disassemble the motor, take note of which face of the motor aligns on the extruder. You can get it assembled wrong, which will frustrate you when plugging in the cables.
I was going to say the same thing.
I usually start back from the cfs and work towards the print head, but either way will work and pressing the retention ring on the tube will let you pull out the tube around the filament then snip the filament. When you get to the bottom of the cfs, be sure to press in the button on the bottom center to release the tension so you can pull it out (this is the hardest part for me since I don’t have a lot of strength in my hands, but it can be done).
Thank you so much for your help! I followed your instructions step by step, and it worked. I managed to remove the filament from the CFS and the PTFE tubes. However, I think the remaining filament is stuck inside the extruder, so I may need to open the extruder to remove it. I really appreciate your guidance!
Thank you so much for the detailed explanation and the videos! I’ll try these steps carefully, one at a time. I’ll also make sure to note which side of the motor aligns with the extruder before removing it. Hopefully, I can clear the jam successfully. I really appreciate your help!
Awesome. Glad it helped.
be patient and take it one step at a time.
Pause the video as you do each step.
