I’ve a Falcon 2 that work perfectly, the only problem that I have in lightburn is that the framing button doesn’t work and the machine stay busy one pressed.
Do you have any suggestions? Because without framing is difficult to align properly.
Dear GAB25
I am having same problem. When you press the frame button does it zip to start point then freeze.
What i have found is that it doesn’t freeze but slows down to a very slow speed. I must have altered something in the settings to drop the speed right down. Have not been able to find ware.
Allthebest AJ
The pattern that I believe is happening with mine is that the first time I try to frame with the laser head idle, it Quickly moves towards the origin but violently stops and stays busy. The last command sent is M3. I have to hit STOP and can then frame successfully. If I home first or just move it at all first, frame works fine.
