Hi All hope someone can assist me i was gifted a a Creality Falcon 2 Air Assist pump , how do i wire it up so that i can use it on my Falcon 10watt, i have got a 24v 3.5a Power supply , but i assume i can connect directly i need to activate or trigger the pump some way any suggestions or recommendations
It is not directly compatible, the Falcon 10W/7.5W air assist gets plugged directly into a wall outlet while the Falcon 2 air assist is connected to the laser, the Falcon 10W does not have the connector. If you wire it up yourself, in most situations you can just let it run while the laser is running with a power supply or so.
