Halot Mage 8K cleaning help.
hello.
I picked up a Helot Mage 8k that was no longer used due to a broken lcd screen. easy enough to replace. but the guy left resin inside and it leaked in to the reflective surface between the lcd and uvs. Im new to resin printing and want to ask whats the best way to clean this mirror. to see if this printer can be usable again.
Isopropanol and a lot of patience. If there’s semi hardened resin it can sometimes make sense to cure it to make it easier to peel off. Don’t use hard metal scrapers. It’s a bit tedious task to do so.
