Hi, I’m victriokook.
I made FullArcCAD, a FreeCAD extension that brings Fusion 360-style usability to FreeCAD. I’d like to share it with people using CAD for figures, miniatures, garage kits and scale-model projects.
The interface includes Japanese/English ribbon menus, an object browser and a modeling history along the bottom of the window.
There are nine task tabs: Solid, Surface, Mesh, Sheet Metal, Plastic, Manage, Utilities, Sketch and Drawing. Context-specific tabs appear as needed.
Main modeling tools include:
• Sketching: lines, circles, arcs, splines, dimensions, geometric constraints, projection, mirrors and patterns.
• Solids: extrude, revolve, loft, sweep, holes, fillets, chamfers, shelling, Boolean operations, body splitting and scaling.
• Repeated geometry: rectangular, circular and path patterns, plus mirrors and alignment.
• Surfaces: patches, boundary surfaces, offsets, thickening, trimming and stitching.
For people working with STL and other meshes, the menus include moving, rotating, resizing, separating disconnected parts, plane cuts, hole filling, smoothing, subdivision, facet reduction, normal correction, face deletion, small-component removal and mesh inspection.
There are also tools for creating meshes from CAD, converting meshes to CAD shapes and creating sketches from mesh sections. These operations have limits depending on the geometry.
Other features include components and joints, interference checks, TechDraw drawings, bills of materials and STEP/STL export. Sheet-metal tools and a limited CAM workflow are also implemented.
Fusion-style shortcuts include E for Extrude, H for Hole, F for Fillet, M for Move and S for command search. Modeling operations can also be reopened from the history for supported parameter edits.
Windows and Linux packages are available. FreeCAD must be installed separately. FullArcCAD is still under development and does not reproduce every Fusion 360 feature or workflow.
If you’re interested, give it a try. I’d appreciate feedback on the workflow and which tools would be useful in your projects.
Downloads:
Moderator Edit:
We are not allowing links to untested or unverified files because of possible virus or other dangers to our Creality community.
Thank you.
Introduction video, showing an earlier build:
Questions and feedback: victriokook@gmail.com
For bug reports, please include your OS, FreeCAD version, FullArcCAD version, and steps to reproduce the issue.
