Please, someone have the preset of nozzle 0,2? There Is only the 0,4 preset in creality print, i’ve tried to modify parameters without success.
Oui moi aussi je suis preneur d’un profil qui marche avec buse en 0,2mm, car c’est introuvable, et je me demande pourquoi il n’est pas présent dans creality print…
Creality does not seams to sell 0.2mm nozzles for the V3 KE officialy, so that may explain why they did not made a profile for it. You can always use a 0.4 profile and edit values to compensate for a 0.2.
| Setting | exemple 0.4 profile value | Ratio from 0.4 to 0.2 | new value for 0.2 |
| Hotend Temp | 220°C | -2% | 215°C |
| Print Speed | 100mm/s | ±0.45x | 45mm/s |
| Layer Height | 0.20mm | ±0.5x | 0.10mm |
| Extrusion Width | 0.40mm | ±0.5x | 0.20mm |
| Retraction Distance | 1mm | ±0.6x | 0.6mm |
| Etc… |
I got myself into wanting to print precision parts and will do a profile myself at one point and I have this prepared. May update with full profile once done.
In any case, you got the basics and start with small test/calibration print when doing a new profile.
