Help! K1 Max says Error Key 109 Fan Feedback Exception
The printer nozzle heats fine. The Extrude function works fine. The fans seem to be operating fine when I turn them on and off with the Settings control sliders.
But I can’t print anything because it says Error Key 109 Fan Feedback Exception.
When I look for a solution I find the Creality site that says the throat fan might need to be replaced, or the nozzle board might need to be replaced. I DO NOT KNOW what either of those things are.
Please help. This printer is only four months old.
OK, so I know this is a rather old post and I’m not sure if the poster ever got an answer. I had the same issue so this is how I found the post. After pulling my print head apart I realized that the fan for the hotend, not the part fan, had come loose somehow. It’s on the left side of the print head on the back side of the board. I pressed the plug back in fully and It’s working perfectly now. Very simple fix.
Any other possible solution? I replaced the board and both fans in the Extruder. Same error. Very frustrating
Soooo my k1max has been down foe weeks …key109 fan feed back exception.
First i replaced the board on the extruder that Creality sent. Didnt fix…Then replaced both extruder fans. Still have same error. Of course it died during the christmas rush. If i dont fix i have to refund every order. Frustrating
What is the fix for this ? Anyone?
Hi, i had the same problem, KEY109 Fan. It’s the little hide fan in the extruder head.
See photo’s. If you are lucky, it’s only some mesh blocking the fan. Otherwise it can be wiring, connector or fan must be replaced.
It’s pretty easy to open the frontcover, remove the cable connectors, then 3 screws.
Thank you so much for the picture.
I realized that I have plugged in my fan at the wrong connector durring assembling. There is another fitting 3pin connector on the pcb, that was running the fan, but obviously not recognizing it.
Now it’s running again.
