Help with Ender 3 v3 SE
Hi All hopefully someone can help me.
I have the above printer, put it all together but when i try and print anything from the SD Card it does not print. it seems to go through the motions but the print duration is 1 or 2 seconds?
Not too sure what the issue here is tbh.
Also, i was previously using Creality Slicer on my old Ender 3 Neo which finally died the other day hence this new one.
What should i be using Slicer or Print? I have an older Mac and am unsure as there does not seem to be a profile for this new printer
Help please
Creality print 4.3.8 is what I use for my V3SE, tried 5.1 but doesn’t work. As for printing is the SD card working ok? The card slot on the V3SE does seem to eat SD cards, best get some 8GB spares in.
Looks like for Mac the latest one i can use is 4.3.7
I will go out in a bit and see if i can get hold of another SD
Just been looking at this again, when i go into print i can see it’s contents, i select 1-cat abs it says estimated time is 1hr50 or something. I get it to do a calibration but when it gets to try abs print, the printing time is 00:01. This is, quite annoying
This is getting quite tiresome, got Creality Print, selected the printer fine, sliced and put on card, when i select the item there is zero in estimated time, print takes 3 seconds and then have to confirn. Very odd.
CAT print does give a duration but no print, same as above
I dont know what to do here
