hello
I have recently purchased the K2 Plus combo and set it up today. on the beginning of the first print i keep getting the error message CF0109 abnormal heat break fan! Any help would be appreciated
Did you sort your problem? Just unboxed my K2 plus and Im getting the same CF0109 error. Any ideas would be appreciated.
Did you ever figure it out? Mine started doing it to me tonight. Think it may be software update related
Re: CF0109, please try:
https://wiki.creality.com/en/printers-general-documents/CF0109
For posterity, im replying to this. I also have struggled with this and gotten support that was less than helpful. The fan, i believe, gives feedback to the board, but if not, the same thing is at fault - the board. I can fool it to keep running by doing a few different selections and getting past the fault. I have already confirmed the fan is functioning correctly, so only downstream of the connection makes sense. I got support to send me a replacemeny fan, which i will install now and report back. But my background tells me it is actually on the board or software. The latest SW update slowed this issue down, but didnt solve it. It is still possible the firmware could solve this issue…
Did getting another fan resolve the issue?
Hi,
In fact, yes, replacing the fan does seem to have resolved my problems. I think there was an issue with the feedback to the main board, making it think somethimg was worng with the fan.
Originally, there was one type of fan - 2-wire, and life was good. Then came along 3-wire and then 4-wire fans, adding Run/PWM/analog input, PWM/tach/locked rotor output, etc. These then started appearing in several variants (open-collector, totem-pole, TTL, etc.) The different permutations thereof have since exploded out of control; many fans today are custom-made. It very well could have been some small anomaly with this particular fan, even if it seemed to spin fine, and it’s likely that the only suitable replacement is OEM.
Same issue on first print out of box 1 week ago today and every attempt to print anything. Seems like fan might be defective from factory OR it is a hit or miss issue. Trying to get through Customer Support is a pain. No diagrams, no disassembly information, no clue on what to take apart. I dissection documentation would be helpful.
Whet gets me is that on first print, the printer pooped out some filament! Never loaded any of my own. The filament was black & grey and my first print was white. I they tested this unit at the factory, they should have seen the error then and resolved it.
trudging through to get this fixed….
Same story here after 111 h printing fine I got the message and no more printing. The shop where I bought my machine is very helpfull and send me a new board. After replacement, same problem. Now waiting what they send me now. Maybe a fan, but they where out of stock. I love the K2, but this is a major problem. The job send me with the board a little bottle of wine for the pain. Good thing, but I hope not to be alcoholic after more things to replace.
The shop is very helpfull, they send me a new fan.
