Help with moving parts
I’m having issues when printing things with moving parts such as spinners. Often most moving parts work fine but more embedded things like print in place bearings fuse and can’t get them moving.
Any tips would be appreciated
Hi, I don’t have Ender-3 v3, if layers bond too tightly, it can cause embedded parts to fuse. Adjust the layer height and printing pressure to reduce the bonding strength between layers. Typically, layer height can be found in “Quality” or “Layer Settings”, while print pressure may need to be controlled indirectly by adjusting the extrusion amount or flow.
