I just updated to the new firmware 1.3.3.26 on a K1 Max. I previously had the machine rooted and had fluid running on it. I did not do a factory reset prior to updating. I did one after. I then attempt to re-enable root access wait the 30 seconds so I can add everything back, but its like it doesn’t take. When I try to SSH into the printer, Mobaextern says no root found. Without being able to ssh into root, I am unable to reload older firmware or try to reload this new version. Is there anyway to force it to reload the firmware without ssh into the printer? Any way to force root access?
I was able to get in using putty instead of MobaXtern.
Hello @J_B1 …! ![]()
PuTTY has been my go to for other things. Never used it for my printer though… ![]()
Glad you were able to get it back to the way it was. ![]()
Hi. I got the same problem but I did reset my firmware proir updating to 1.3.3.26. Everything works fine exepet I cannot SSH into the machine after the updaten even if I allowed rooting in the setup menue and got root name and password. It seems this update is blocking root access. Any idea how to proceed?
I’m having the same exact problem, but with a K1C . After last update, no more SSH… The port appears filtered and I can’t do nothing…
Are you certain you have the latest update? I have installed 1.3.3.36, I did not reset printer defaults before updating but I saved all the config files to my pc before updating. The only problem I had was that the new version deleted the moonraker.conf file. All worked ok after copying the file from my PC. Also SSH worked ok with putty
Bill
I reset to factory from the machine, the updated and installed my CFS to my K1 max. After the update, I cannot run the root script. It says it is not a valid directory. Any idea how to correct this?
This method worked for me, just be aware that you can’t install the adaptive mesh/purge line as it breaks the CFS
