Hello, I have rooted my printer with the Creality Helper Script. I then installed the M600 support, but unfortunately it does not work properly. There is probably a transmission error from gcode_macro.cfg at [gcode_macro QUIT_MATERIAL]. The instruction “G1 E100 F300” is missing a 0 in the helper script “G1 E10 F300”. The problem now is that the cfg file “/config/Helper-Script/M600-support.cfg” is disk protected. Does anyone know a method how I can make it writable? I have tried the normal way with “sudo chmod a+w”. Although you then have write permissions in the system, the file is still write-protected in Mainsail, at Maschiene.
Regards Shredder
The PASUE & RESUME macros should already be in your macros to use. Just have your slicer place the word PAUSE in your GCode, then when you are ready to resume click on the RESUME macro in your web interface.
Yes, PAUSE(M601) works. M600 moves to the side and already unloads the filament. The missing 0 (apparently) causes the filament to run off in the extruder and then harden and no longer comes out at the front or back. This means that I have to dismantle the extruder every time.
This would be translated from German into English.
Ja klar, PAUSE(M601) funktioniert. M600 fährt an die Seite und entlädt schon das Filament.
Die fehlende 0 bewirkt(scheinbar) dass, das Filament im Extruder abreist dann erhärtet und nicht mehr nach vorne oder hinten raus kommt. Dadurch muss ich jedes mal den Extruder auseinander bauen.
