If you’re trying to use Cura with a V3 and want the thumnail to show up on the printer like it does with Creality Print, you need to go to extensions/post processing/modify g-code
add the plug in ‘Create thumbnail’, set it to 96x96
add a second instance of the plugin ‘create thumbnail’ and set it to 300x300
Thank you very kind
יש לי אנדר V 3 KEולא הצלחתי אשמח אם תעזור לי
