Hey and Issues/My K1C/Nylon Glass Fill?
So, the K1C seemed off. I went to tighten some screws and take it apart. I ripped the ceramic heater core and thermistor wires right out of their respective connectors.
Since then, I have tried to reattach a new heater core and thermistor. Here is the issue.
When taking the hotend connections apart (screws). Two of the four screws are fastened with thread locker. Although this was an issue at first. I finally got the last of the two thread locked screws unscrewed.
Since then, I would like to know where the thermistor attaches to the control board. So, where should I attach the thermistor to the control board?
Is it the connector that is located two above the heater core connection?
Seth
Okay and I think I found the connection to the control board. It is the connection to the left of the heater core.
Seth
Has anyone used Glass Fill Nylon on the K1C yet? I cannot get the Nylon Glass Fill to stick past the second layer.
I will try a different bed plate. Maybe the Textured PEI and PEI plates are not meant for the lack of sticking for the Nylon Glass Fill?
Seth
