Problem sending prints via Wi-Fi to Creality Hi Combo
Hi everyone, I’m having a recurring issue when trying to print via Wi-Fi with my Creality Hi Combo using Creality Print.
When I send a file to the printer, the process often gets stuck during the G-code transfer/upload window and doesn’t progress, so the print never starts. Sometimes it works normally, but other times I have to retry the transfer several times before it goes through.
It doesn’t seem to be an Internet speed or Wi-Fi signal issue because:
My Internet connection is approximately 100 Mbps.
The printer is located right next to the router.
The PC running Creality Print is connected to the router via Ethernet cable.
The issue mainly occurs while transferring the G-code to the printer.
Has anyone experienced the same problem with the Creality Hi/Hi Combo?
Is there any network, router, Creality Print, or printer setting I should check or change to make the G-code transfer more reliable and print over Wi-Fi without having to retry several times?
Any solutions or settings that worked for you would be greatly appreciated. Thanks!
