How to actually z-offset my printer?
Hi,
I have a cr-10 se printer that I overall enjoy, despite plenty of fails. At first it was since the model detached from the bed, I increased the first layer temperature, decreased the other layers to 195 and the bed temperature is at 60. This helps a bit, but what really fixed it is printing one element at a time, rather than one layer. Still one of the prints failed, and from what I understand, the issue is that the printing head is a bit too low. Maybe 0.05m I would like to put it up but I have no idea how. I couldn’t find any real guide for that, and the printer let’s me configure it only while printing (which means that this is a per-print config).
How do I actually do this?
Hello !
From my knowledge, you have two possibilities if you can’t via the screen:
  • With the slicer, in the profile profile
  • or by adding a line in the start g-code. Your printer is still by default in Marlin ?
My printer is still in the default firmware, yes. I recently updated it (from the internal setting menu). I didn’t have the time or the nerves to go through the root process.
Cool profile photo
In the slicer, try to put the value you find via the screen with this code :eyes:
M851 Z-1.25 ; remember that negative = nozzle closer to bed
(replace the value after Z)
It will force this value for each print
thanks, where do I put this? That’s my main question. In the machine start g-code?
Yep in the start-gcode ! Generally after the leveling (if there is one) and before the wipe line :slight_smile:
I don’t see anything about leveling (the the printer does that), I do see this which looks like the wipeline to me
G1 X-2.0 Y145.0 Z0.28 F1500.0 E15 ;Draw the first line
G1 X-1.7 Y145.0 Z0.28 F5000.0 ;Move to side a little
G1 X-1.7 Y20 Z0.28 F1500.0 E30 ;Draw the second li
There is something that confuses me, after I replace a nozzle, there is no way that I’m able to reinstall it a the exact same height. Same for if I replace a printing head or a motor or what not. This is the only way I’m supposed to update the z-offset? There is no way to do this with a regular UI?
OK, something is weird. I’ve added that line. The line I’ve added to the printer is
M851 Z-0.656
However, the printer shows that the offset is -0.651.
The print itself is fine, so far
