I need to figure out how to disable the multi-point bed level feature for some prints (printing two colors: first color 0.4 mm height, then overprint with secondary color). The problem: the bed calibration often hits on the printed stuff making it print poorly. I can work around a single center calibration by placing things more carefully on the print bed. I recently updated the firmware, and see that every print has full bed calibration occurring. I checked creality print printer settings, and there is no G29 line in there. I did not see anything on the KE pad to turn that on/off. What do I need to do to stop this from happening please?
Hello
I’m sure you’ve probably read this article already but it was something I came across and thought it may help you.
Good luck ![]()
Thank you! I’ll give it a try. To comment out the line do I simply put a ; at the beginning of the line?
