How to hook up laptop to 3d printer
laptop to printer
Hello !
What do you mean ? By cable ? By WiFi ?
by wi-fi,thanks
Is the Laptop on the wifi network? can you get to the internet through the laptop? If the answer is yes, then I think it is safe to assume the laptop, and router are set up correctly.
What do you see in the Network menu of the K2?
yes,everthing is working right, charlie
I still don’t understand. It is generally automatic by using the Slicer (CrealityPrint 6.3 or 7.0 beta)
Both are connected to the same wifi => The slicer finds it
Why use wifi.? I use cat 6 to 2,5G network
@Brian_Edwards sometimes running a hard wire is not practical. I don’t know shidues configuration, but in my case, the printer is in the garage, router is in the kitchen. Just no good way to get from point A to point B. Besides, it is not like the UI and gcode are a lot of network traffic. The slower speeds of Wifi are negligible.
