It is necessary to stop printing on a certain layer in order to put the nut inside the model.
I didn’t find the pause function in Creality Print.
Pausing through Cure has no effect.
Tell me how to pause.
In Creality Print there is a button near the top of the screen to pause.
If you have a K1 or a K1 Max you can also pause using the screen.
Stopping “manually” is inconvenient.
There is a special function in CURE.
For MARILYN, you can put a function in GCODE.
It is logical that there should be a PAUSE functionality for K1.
And so you can turn off the power))) after switching on, the printer will continue printing further)))
colleagues, does no one really have a solution to the “PAUSE” problem?
So what you are wanting to do is edit the gcode with a gcode editor so the printer stops automatically at a certain point?
I'd like to know also. I'm not at that level yet. Sorry.![]()
There are several ways to do that, if you have rooted your printer. If not, you can save your GCODE file, and edit it before send to printer. Just open it in a text editor, find the layer number and insert a line with the word “PAUSE”.
Hi!
Simply edit your Gcode with a PAUSE command at the layer you want.
It works!
I had a great deal of learning to have the print job auto pause at a certain layer. I posted my journey on the 3d printing forum. Read the following link.
Tried several different commands that Creality Print ignored and then I was able to just use the PAUSE command in the K1 Max (Not Rooted).
Used a text editor (NCnetic V2) I think you can use NotePad ++ Also..?
Hadn’t done this before and had to manually press pause when the printer was on a certain layer.
Note: For some reason this gcode for a benchy didn’t show the layer numbers. It just shows LAYER_CHANGE which makes it a little harder to figure out which layer to pause on.
Fortunately other model gcodes show the layer number.
Hello @Rhedegydd …! ![]()
Thanks for that example. It’s a lot easier to do now in Creality Print 5. I gave an example from 4.xxx. Kind of a pain… ![]()
Not a problem… Thanks for the input…
Did you get a K1 / K1 Max…? and what do you think of it so far…
Bro… do you know how many people you’ve helped with this screenshot? YOU have no idea…
Mate, you have become in the savior of thousands of people
You can pause print, by right clicking the layer bar after slicing to add pauses, og modify g-code.
Hope this helps someone ![]()
I have found that the pause command can be pretty much hit and miss. Occasionally it will actually pause the print at the correct point in the execution of the print file however most of the time it either falls to pause completely or pauses on the wrong level.
I’m using Creality_PrintV5.1.6.10470 Release and I’m printing on an unrooted K1 Max using Version 1.3.3.36
Hello @kccourier …! ![]()
I had some issues with 10470 so I went back to 10249. Pause has been working pretty well.
Stock K1 Max no root.
Thank you sir! It did help, and did exactly what I wanted. For others with a K1Max that want to change colors. Although you can specify multiple colors (spools) in Creality Print 6, using this to pause a K1Max does not appear to work. This method of pausing works!
The Kapt
Make sure you account for the fact that the pause occurs at the beginning of the layer.
Pausing didn’t work in Creality Print on my K1C. I added a pause at layer14… it just continued to print.
How does this feature not work properly?
I just recently bought my k1C… not impresse
EDIT: I find that I had to manually insert PAUSE as the command in the g-code.
