I’m using this filament for the first time:
https://aurarum.com.au/shop/aurarum-pa12-cf15-nylon12-3d-printer-filament-carbon-fibre-1-75mm-1kg/
I cannot get the filament to stick to the stock bed even with glue applied - it does not stick at all!? I just end up with a bunch of spaghetti moving around the bed with the nozzle.
I had to create a new Creality Print filament profile with these settings:
Nozzle Max: 240
Nozzle Min: 200
Chamber temp: 70
Nozzle first layer: 230
Nozzle other layers: 220
Bed temp- Smooth PEI plate (Stock plate)
First layer: 90
Other layers: 80
No cooling for the first 3 layers
Min fan speed: 30
Max fan speed: 60
CP settings:
Layer height: 0.2mm
First layer height: 0.3mm
First layer speed:
First layer: 50 mm/s
All other speeds set to 50 mm/s
K1 is about 3 months old.
CP is version 5.1.4
Model is: https://www.thingiverse.com/thing:763622/files
Nozzle Max: 240
Nozzle Min: 200
Chamber temp: 70
First layer: 90
Other layers: 80
Min fan speed: 30
Max fan speed: 60
CP settings:
Layer height: 0.2mm
First layer speed:
CP is version 5.1.4
