Hyper PLA badly stringing on thin objects
newbie question, when I use the creality hyper pla , on larger objects it works fine with the default settings, but on objects that are thin I get a really bad stringing situation, I did the retraction test calibration and didnt get any stringing at all there, but then I print something and I get a hairy mess, any ideas? also , isn’t the camera supposedly using AI to detect failures?
thanks
Do you have a filament dryer? Did you dry the filament?
Also check for other issues like overextrusion that can also cause stringing.
I will check on overextrusion, about the drying, I am using a brand new filament out of the bag, and it doesn’t look brittle
Check the nozzle temperature. Too high for the material you will get stringing…
Сушить нить имеет смысл в любом случае, даже если она только сто из упаковки.
А вот насчет неработающего И с определением “лапши”- я заметил, что действительно, эта функция НЕ РАБОТАЕТ в СпаркХ (((((
