I absolutely need your help with my K2 Plus
salut a toutes et a tous je viens vers vous car j’ai un soucie avec ma k2 plus. J’ai récemment une un problème avec ma tête d’impression buse bouché, extrudeur ne prennent plus de filament et problème de moteur extrudeur. j’ai don fais le ménage en grand, remplacement de la buse changement du moteur et de l’extrudeur recalibrage du nouveau moteur mais toujours le même problème mon filament ne passe pas.
donc là j’ai vraiment besoin de votre aide merci d’avance.
Hi everyone, I'm reaching out because I'm having trouble with my K2 Plus. I recently encountered a problem with my print head: the nozzle is clogged, the extruder isn't feeding filament, and there's an issue with the extruder motor. I've done a thorough cleaning, replacing the nozzle, the motor, and the extruder, and I've recalibrated the new motor, but the problem persists: my filament won't feed.
So, I really need your help. Thanks in advance.
Hi @Brahemorik !
Did you encounter this problem while starting printing? Do you use CFS? What error does the printer shows? Did you check the PTFE tube? Is it clear?
Best regards,
Krzysztof
Sorry to hear you are going thru that. A couple of things to consider is - did you replace the hot end also or just the nozzle? Did you perform a PID Tune on either replacement? Did you verify there was no stuck filament in the gears of the extruder? Did you push filament from the affected CFS line, thru the PTFE tube all the way to the printer where it outlets at the print head?
