I Can't delete a gcode file from ender 3 v3.
When I use the touch screen to select the item, I get the option to delete, but then when I click delete nothing happens.
Hello @Bill_Chandler …! :wave:
It should delete the item if you are selecting the item (long press and select the circle) unless maybe it’s a built in gcode such as a benchy or filament holder…?
You could delete an item using Creality Print 5.xxx in the device list in details and the file list. Click on the item and choose delete. It will delete it off the printer also..
Can you delete using the Fluidd web interface?
Selecting the circles that I wasn’t seeing until now worked. Thanks. I was long pressing and then clicking delete. I didn’t realize I needed to select the file(s) afterwards and then hit delete. Simple.
At my school I haven’t been able to connect it to the internet, so the web interface doesn’t work. I’ll have to try it at my house.
Thanks to both of you.
Does not need the internet as such, if it is connected to your network, find the IP address of the printer and enter that into the browser to get to the Fluidd interface.
