Import a .SVG to print as a different color into Creality Print
I’m using CP v7.0.0.4127 and what I’m trying to do is merge an imported .SVG file into a rectangle (for example). Then I want to print the rectangle one color (blue for example) and the imported .svg another color (red). And I want these to be flush.
How do I go about in doing this?
Thank you!!
Load the rectangle, select it and right click on it. Add Part > SVG and import your SVG File. It will give you options like depth, etc. This will make it an assembly. Move the SVG into position where you want it.
Then on the left side under the printer drop down, you should see the rectangle and svg listed as objects. Select the SVG and change the filament color.
Is the filament an extra for the falcon A1 pro?
uh…what?? The question was about Creality Print not an engraver.
