Hi all, i have a small problem I’m sure someone has had before…when i import anything into creality print from a 3d softwware that is round or is an arc, the model is not round, it is alot of straight lines in a circle. I can’t figure out how to import the file so that the arc or circle is smooth. Any help would be greatly appreciated!
The STL file you are outputting needs finer resolution, STL is triangles so the smaller the triangle the better the curve or better still use a STEP file for proper circles.
Thak you, thank you, thank you!
You’re welcome, You’re welcome, You’re welcome. ![]()
