More info about K2 PLUS & CFS from our product team you’d love to know.
For those who don’t want to watch the whole 10min video, here are the summary below:
350x350x350 print volume
Linear Rail on X axis
Air conditioning module inside the chamber, heat up to 60 degree and air circulation to cool it down along with air filter
Wider hinge for front glass door
Megacasting frame
CFS(Creality Filament System), 4 rolls each, up to 4 expansions, that is printing with 16 rolls at the same time
CFS with Temperature/Humidity control
Support Creality RFID filament as well as non-RFID filament(user define right on the display)
Up to 350 degree nozzle
Up to 120 degree heat bed
AC heating heat bed with 800W power for quick heating
Support most type of filament(except PEEK or PEI)
Dual chamber fan cover the whole bed, much efficient cooling when printing overhangs
Dual Z with thick axis
Closed loop motor(quieter) with FOC(Field oriented control). Dynamic power, use more power when it need more torque; use lesser power when it don’t need that much torque. Advantage, generate lesser heat.
Magnetic extruder kit cover for easy removal
Longer hotend to catch up with the flow rate when printing high speed
Hardened steel extruder gears
CFS use 485 communication protocol, no external power need, all 4 CFS(around 10w each) can draw power from the machine
Translation video from a friend:
Original Source:
