Hello, I would like to know if the model, CR-Laser Falcon CV-30 5W, works for me to insert board games in 3mm MDF
Thank you so much.
Thank you so much.
You want to engrave board games on MDF? Yes should work. Do you also need to cut them out?
Yes, I also need to cut them
Would also work with thin material but be extremely careful with the fumes when cutting MDF, burning the glue that is in there can be unhealthy when burned.
