Interrupted prints
Hello!
I have been having some issues with my printer where it throughs the model outside the build plate; somehow.
I had a model that needed 26 hours of printing. One hour before it was completed, I checked on the printer just to realize that the model was somehow thrown outside the build plate.
Not sure if this is due to Z-axis offset screw up from the printer.
Has anyone had the same problem?
Was the object “bumped” of the buildplate or did you have “layer shifts” (part of the object moved!)?
What do you meen, “the model is thrown out of the plate” ?
Is it not adhered on the plate? Is your bed temperature correct so that the print can stay on the plate?
If an object is only touching the buildplate with a small part you can use a brim…
