Is K2 usable with CFS for anyone?
I just got a K2 with CFS, or rather, I just got, returned, and replaced a K2 with CFS, and I’m still having nightmarish problems.
Though this is a new printer, I’m not exactly new at 3D printing, having used a Snapmaker for half a decade. I’ve never seen a 3D printer be as completely useless as this one is. Out of dozens of attempts, I’ve only had two attempts make it more than a quarter inch off the print bed before failing to swap filaments. And it is currently unable to even make it through the Self-Check process without throwing an error more often than not.
The only question in my mind is whether I’m missing something that is easily fixable, or whether this printer is simply fundamentally designed wrong in a matter that can never be fixed.
I’m using Creality PETG (non-Hyper) and breakaway PLA.
After a brief period of working correctly, just enough to get a third of the way through a single model, the filament switching began failing more and more often, until loading the filament fails approximately 100% of the time.
Most of the failures are either:
  • Bogus clogged tube errors
  • Bogus clogged extruder errors
  • Not extruding errors
Sometimes, it fails claiming (falsely) that the tube is clogged.
I’ve already tried:
  • Swapping the filament sensor
  • Swapping out the cutter
  • Bypassing the buffer
  • Adding a plate to extend the cutter spike
  • Lowering infill / wall overlap to 15
  • Verifying a clear path through the cold part of the extruder and verifying it can move filament by hand
  • Downgrading to 1.1.2.6 — no difference
  • Downgrading to 1.1.1.7 — would not install
  • Print temperatures as low as 140 and as high as 180
  • Switching from Creality PETG to Overture PETG — no difference other than worse adhesion for the brief moments of successful output; still issued a clog error
There is no evidence of clogging in the hot end. When filament moves at all, the extruder works normally. It just isn’t pushing the filament out reliably or extracting it reliably. It almost acts like the output hole in the plastic block above the hot extruder block is slightly too small. For every PETG filament, including Creality’s filament.
Current firmware. Calibration does nothing.
I’ve had it for only two days, and I have gotten a whopping sixty-three errors as of an hour ago, and that’s before I started trying firmware downgrades and alternative filaments. The errors are listed below:
AC0521
AC0104
AC)119
CM2784
F00528
CM2784
CM2784
CM2784
FR2865
FR2849
FR2849
FR2836
FR2836
FR2836
FR2865
FR2836
FR2836
FB2844
FR2836
FR2836
FR2836
FR2836
FR2836
FR2849
FR2849
FR2849
FO2837
FO2837
FR2849
FO2845
FR2836
FR2836
FR2836
FR2865
FR2836
FR2836
FR2849
FR2849
FR2849
CX2585
CX2586
CX2585
FR2849
FO2845
FB2847
FR2845
FR2836
FO0528
FR2849
FR2849
FR2836
FR2836
FR2836
FO0528
CM2784
FR2865
FR2836
FS2843
FS2840
FO2845
FR2851
FR2851
FR2836
Is this a typical user experience? Because this is by orders of magnitude the worst experience I’ve ever had with any 3D printer. Should I just write off the entire platform, ship it back, and buy something else? Because I’m at that point after just two days of absolute failure to print anything.
The best part is that this is my second Creality K2 Plus. The first one got here less than a week ago and went right back to Amazon because the Z axis was making an awful buzzing noise and the print head was crashing into the front of the front and back of the enclosure repeatedly while printing. Completely out of control. And the layers kept not adhering, etc., probably because the Z axis was hosed. No way was I going to deal with a lemon like that, so it immediately went back.
I think it was switching filaments correctly, but its failures were so catastrophic that it didn’t even make it to the few hours of printing when this second one started failing, so that isn’t necessarily an indication of anything.
Barring that last version downgrade turning out to be a miracle, this ons is probably going to go back, too.
Before I ship a second Creality K2 back to Amazon and walk away from the brand forever, is there anything else I can try to make this thing actually extrude more than 5% of he time?
Thanks,
David
I think I might have found the problem, unless my success is a fluke. I read a post talking about the temperature somebody else was using to print with Overture PETG, and was shocked by it being a whopping 285 degrees, which is 35 degrees over the maximum recommended by Overture.
The post also noted that the automatic temperature adjustments based on flow do not work correctly, and result in the temperature being too low.
Cranking the print temperature up to 285 degrees appears to have solved the clog. It has been printing for over two hours with multiple filament changes, and it hasn’t jammed up and ground a thin spot in the filament even once in all that time.
So apparently, either:
  • There’s a bug where the filament swap does not run nearly hot enough relative to the print temperature, or
  • The nozzle temperature is off by about forty degrees.
Amazingly, I’m pretty sure it is the second one. My Snapmaker prints the exact same PETG reliably at 245 degrees. At 245 degrees in the K2, the filament comes out as cold strings that don’t fuse correctly, so I had already experimentally pushed the temperature all the way up to 260 degrees — ten degrees above the manufacturer-specified maximum — just to get a usable print.
So apparently, the nozzle temperature is off by at least 15 and no more than 40 degrees. That’s terrifying, particularly given that one of the filaments giving me fits was a genuine Creality filament, and you’d expect that they at least tested their own stuff.
My first thought was a bad nozzle temperature sensor, but on two printers in exactly the same way? It almost has to be either too low a voltage going to the temperature sensor (hardware design flaw) or a software bug. Maybe I should try powering the thing off a Jackery instead of my probably-below-normal household line voltage and see if the issue goes away, but I wouldn’t think anybody in their right minds would use an unregulated power supply for something like that, so I’m not holding my breath. :joy:
Anyway, problem at least partially solved in that the printer is able to print something. I still haven’t found the root cause, quite, but at least I’m within spitting distance of it.
Well, it almost worked. Except that the amount of time it took to switch filaments and print some of those areas of breakaway material was sufficient for the top layer to cool down, resulting in inadequate adhesion, so the model came apart between layers while pulling it off the bed, and with a little tugging, ended up in five parts.
This, coupled with the almost complete lack of strings, tells me that the nozzle temperature is actually MORE THAN 40 degrees higher than it actually is.
I’ve ordered an IR thermometer. It will arrive later today. Will follow up.
It’s hard to get a good reading from an IR thermometer. On my Snapmaker, with the temperature set to 240°C, the highest reading I managed to get was 203°C.
But on the K2, at 240°C, the highest temperature reading I could get was 173°C, a whopping 30°C lower.
So at this point, I’d call that an absolute confirmation that the temperature sensor in the hot end is likely defective, and I need a new hot end.
How I managed to get two 3D printers in a row with that defect is beyond me, though. If you want to know what lottery numbers not to pick, I’m your guy. :joy:
I’ve emailed Creality and asked them to send parts.
Thanks for posting your experiences, Dgatwood - I’ve had my K2+ since February and like you it’s been a frustrating experience, but at least I’ve not had the temperature issues you’ve had. My temp seems about spot on compared with my other printers. However I’ve had lots of random issues with the CFS, including lots of “bogus” errors as you’ve experienced. I now print from manually loaded filament where-ever I can, so as not to involve the CFS at all - now I have a much more consistent printing experience. My problem is very inconsistent first layer heights, which is incredible for a printer using direct-to-nozzle strain guage. My previous printer was a Prusa, and I’m really missing their consistency, quality and attention to detail! ho hum…
I should post an update. Between swapping out most of the guts of the extruder, massively increasing the retraction speed, increasing the z-offset way beyond what the front panel allows, and cranking up the number of cooldown moves to IIRC 6, I’m still getting brittle PETG prints that pull apart, but I’m not getting the continuous clogs. It might be under-extruding, or I might need to bump up the temperature more or increase the z-offset more.
Either way, what is clear is that the default settings for both Creality PETG and Hyper PETG are unusable, and doubly so with CFS. :crazy_face:
