My screen flat cable had broken, i buyed a new one, but it will arrive next month. Is there anyway of changing the filament without the screen?
Hello @LEGO_BROS …! ![]()
When your K1 Max is connected to a PC you can use Creality Print to control it and pause to change filament.
Is that what you are trying to do..?
Its impossible to change there is no option on Creality Print
it made me waste filaments and time too ![]()
Hello @Ömürsel_Ocakcı …! ![]()
There are certainly a couple ways to pause through the gcode, the printer screen or on the details page in Creality Print. What are you trying to do..?
You can change material without the use of the touchscreen…
Just go to your printer in your browser… There you can change the nozzle temp, after pre-heating you can safely remove the filament manualy… put in the new filament and manualy press through some material… After that you can start your next print…
