Issue ender 3 v3 plus
Hello,
I have issue with the bed of ender 3 v3 plus
I need to replace it or what i can make ?
Thank you for the help
Is there an issue with your prints? The calibration tells your machine where the plate is. Some variability will be compensated for by the slicer. A span across the 300 mm plate of 0.6mm seems totally reasonable.
But I’m inexperienced. I read your post then some others here and came across a post where a forum user has a wider delta across his plate without issue. So I’d suggest you only worry about it if your prints are failing.
Not only that but the V3KE is a much smaller bed than the V3Plus, biggest thing to do is get the z offset dialled in so the filament is properly squished into the bed, make sure the bed is properly clean, all should be golden.
And check the x gantry is parallel to the bed
My Ender-3 V3 Plus has a bed mesh about the same and has been putting out great prints…
If it’s printing good that means the machine is compensating for any rough spots as @embody_print mentioned.
Also dial in your other settings like @Bonfireman mentioned.
Hello, i have semi-resolve my issue i have up z offset, you know what is the best save z offset in orca slicer or save it in klipper of the printer ?
I would save it on Klipper in the machine, just in case you use a different slicer you can never forget to set it then.
I am here searching for solutions to a bed mesh issue, but check mine out. It’s nuts! I have no idea what might be causing that infinite increase on the one side. Replacing the plate did not help. Running auto-level only gets me a slightly different version of the same thing. Creality support said to re-balance. I have to learn what that procedure is. (Total newb here.)
What firmware are you using?
