K Pro Update 1.1.4.1 malfunction (2026-03-23)
Finished a print on the K2 Pro and an update popped up. Downloaded the 1.1.4.1 and rebooted. Printer sends the table to the bottom and stops. Nothing but a weird low speed fan noise.
I did a factory reset and let it do a function check. Everything turned out good and now seems to be functioning normally.
Did you root the printer and run the script to install options? If yes, you should have reset to factory before updating firmware!
If the problem is stil there, try with updating from USB-stick instead of letting the printer download the firmware!
