K1 + CFS - Cutter not cutting PETG
Good day,
I have upgraded my K1 with the CFS upgrade kit.
After trying to printing with multiple colors, the cutter doesn’t seem to cut PETG properly. I have searched the web for alternative cutting blocks, but couldn’t find any… it seems like the head isn’t moving fast or hard enough against the cutting block to cut the filament. I get this error: TC2841.
After it rams against the cutting block a few times it stops and then reports the error. I then manual move the lever to cut the filament and then retry… then it rams against the cutting block and doesn’t seem to move the lever back to its original position, and I have to manually move the lever back to its original position while its in the process of trying to cut. Sometimes it successful and then the filament gets retracted, and then continues…
This is giving me allot of headaches.
Anyone else found a solution for this?
