K1 cfs hopper
Hi does anyone have the stl file for the hopper my head got jammed and broke the lower section off.
I upgraded my k1c with cfs I know there is a. file on printables does not come out very well where spring is mounted and theres no slot for metal cutter.
Any help would be good or part number for a replacement.
Thanks
How’d you go with this ? Just installed my CFS on the K1C and mid way through a 13 hour print it also crashed into the hopper, breaking the bottom section off. Has also sheared the wires off the extruder motor.
Did you find a file to print the hopper ?
Mine did the same thing but ripped the srews out where it was mounted and now I can’t use my cfs because i have no way of mounting the hopper back on.
