i just upgrade to the newest root firmware.my heatbed will rapidly hit the bottom of machine after homing xy.It always happen when i wanna start print a file.i cant firgue out what happened.maybe someone can help me?
here are my log between select the file to sudden stop.
[INFO] 2025-08-03 20:58:00,832 [root] [virtual_sdcard:work_handler:553] work_handler start print, filename:/usr/data/printer_data/gcodes/yi-sw_PETG_2h15m.gcode
[INFO] 2025-08-03 20:58:00,838 [root] [virtual_sdcard:work_handler:576] delay_photography status: delay_photography_switch:1, location:0, frame:15, interval:1
[INFO] 2025-08-03 20:58:00,853 [root] [virtual_sdcard:work_handler:660] Starting SD card print (position 0)
[INFO] 2025-08-03 20:58:01,040 [root] [gcode:respond_info:301] not prepare.
[INFO] 2025-08-03 20:58:01,044 [root] [gcode:respond_info:301] wait temp end
[INFO] 2025-08-03 20:58:01,109 [root] [toolhead:cmd_M204:695] Record cmd_M204
[INFO] 2025-08-03 20:58:01,115 [root] [gcode:respond_info:301] x_axes is NULL
[INFO] 2025-08-03 20:58:01,133 [root] [gcode:respond_info:301] move xy
[INFO] 2025-08-03 20:58:01,142 [root] [force_move:cmd_FORCE_MOVE:120] FORCE_MOVE stepper_z distance=0.100 velocity=10.000 accel=0.000
[INFO] 2025-08-03 20:58:01,165 [root] [force_move:cmd_FORCE_MOVE:120] FORCE_MOVE stepper_y distance=-14.000 velocity=50.000 accel=0.000
[INFO] 2025-08-03 20:58:01,183 [root] [force_move:cmd_FORCE_MOVE:120] FORCE_MOVE stepper_y distance=7.000 velocity=50.000 accel=0.000
[INFO] 2025-08-03 20:58:01,810 [root] [verify_heater:check_event:63] Heater heater_bed approaching new target of 75.000
[INFO] 2025-08-03 20:58:03,812 [root] [statistics:generate_stats:68] Stats 1707435.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000007 mcu_task_stddev=0.000004 bytes_write=235377323 bytes_read=79363929 bytes_retransmit=0 bytes_invalid=0 send_seq=4298863 receive_seq=4298863 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996901 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547007 bytes_read=26019054 bytes_retransmit=9 bytes_invalid=0 send_seq=1835568 receive_seq=1835568 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999260 adj=120002224 leveling_mcu: mcu_awake=0.001 mcu_task_avg=0.000012 mcu_task_stddev=0.000062 bytes_write=1461340 bytes_read=4597554 bytes_retransmit=126 bytes_invalid=0 send_seq=243059 receive_seq=243059 retransmit_seq=235568 srtt=0.001 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831899 adj=71834051 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000008 bytes_write=1789563 bytes_read=4725125 bytes_retransmit=284 bytes_invalid=0 send_seq=270032 receive_seq=270032 retransmit_seq=265681 srtt=0.001 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999328 adj=50000529 sd_pos=29866 mcu_temp: temp=47.0 chamber_temp: temp=36.8 heater_bed: target=75 temp=59.4 pwm=1.000 sysload=0.89 cputime=133165.124 memavail=139716 print_time=239222.637 buffer_time=0.000 print_stall=1 extruder: target=180 temp=247.9 pwm=0.000
[INFO] 2025-08-03 20:58:06,813 [root] [statistics:generate_stats:68] Stats 1707438.6: gcodein=0 mcu: mcu_awake=0.005 mcu_task_avg=0.000010 mcu_task_stddev=0.000005 bytes_write=235379822 bytes_read=79366109 bytes_retransmit=0 bytes_invalid=0 send_seq=4298990 receive_seq=4298990 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996901 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547109 bytes_read=26019375 bytes_retransmit=9 bytes_invalid=0 send_seq=1835577 receive_seq=1835577 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999254 adj=120002183 leveling_mcu: mcu_awake=0.001 mcu_task_avg=0.000012 mcu_task_stddev=0.000062 bytes_write=1461358 bytes_read=4597602 bytes_retransmit=126 bytes_invalid=0 send_seq=243062 receive_seq=243062 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831955 adj=71834363 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000008 bytes_write=1789581 bytes_read=4725173 bytes_retransmit=284 bytes_invalid=0 send_seq=270035 receive_seq=270035 retransmit_seq=265681 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999335 adj=50000732 sd_pos=29866 mcu_temp: temp=47.1 chamber_temp: temp=36.8 heater_bed: target=75 temp=59.6 pwm=1.000 sysload=0.82 cputime=133165.473 memavail=140668 print_time=239227.784 buffer_time=2.344 print_stall=1 extruder: target=180 temp=241.3 pwm=0.000
[INFO] 2025-08-03 20:58:09,814 [root] [statistics:generate_stats:68] Stats 1707441.6: gcodein=0 mcu: mcu_awake=0.005 mcu_task_avg=0.000010 mcu_task_stddev=0.000005 bytes_write=235381319 bytes_read=79367688 bytes_retransmit=0 bytes_invalid=0 send_seq=4299054 receive_seq=4299054 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996900 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547211 bytes_read=26019709 bytes_retransmit=9 bytes_invalid=0 send_seq=1835586 receive_seq=1835586 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999246 adj=120002117 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461376 bytes_read=4597662 bytes_retransmit=126 bytes_invalid=0 send_seq=243065 receive_seq=243065 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831847 adj=71834922 rpi: mcu_awake=0.001 mcu_task_avg=0.000010 mcu_task_stddev=0.000010 bytes_write=1789599 bytes_read=4725234 bytes_retransmit=284 bytes_invalid=0 send_seq=270038 receive_seq=270038 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999325 adj=50000806 sd_pos=29866 mcu_temp: temp=47.3 chamber_temp: temp=36.8 heater_bed: target=75 temp=60.0 pwm=1.000 sysload=0.82 cputime=133165.790 memavail=139704 print_time=239230.652 buffer_time=2.211 print_stall=1 extruder: target=180 temp=234.9 pwm=0.000
[INFO] 2025-08-03 20:58:12,814 [root] [statistics:generate_stats:68] Stats 1707444.6: gcodein=0 mcu: mcu_awake=0.005 mcu_task_avg=0.000010 mcu_task_stddev=0.000006 bytes_write=235382908 bytes_read=79369291 bytes_retransmit=0 bytes_invalid=0 send_seq=4299122 receive_seq=4299122 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996897 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547313 bytes_read=26020035 bytes_retransmit=9 bytes_invalid=0 send_seq=1835595 receive_seq=1835595 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999238 adj=120002108 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461394 bytes_read=4597721 bytes_retransmit=126 bytes_invalid=0 send_seq=243068 receive_seq=243068 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831805 adj=71833305 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000007 bytes_write=1789617 bytes_read=4725295 bytes_retransmit=284 bytes_invalid=0 send_seq=270041 receive_seq=270041 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999315 adj=50000631 sd_pos=29866 mcu_temp: temp=47.5 chamber_temp: temp=36.8 heater_bed: target=75 temp=60.6 pwm=1.000 sysload=0.84 cputime=133166.130 memavail=139712 print_time=239233.640 buffer_time=2.199 print_stall=1 extruder: target=180 temp=229.0 pwm=0.000
[INFO] 2025-08-03 20:58:15,815 [root] [statistics:generate_stats:68] Stats 1707447.6: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000010 mcu_task_stddev=0.000006 bytes_write=235384459 bytes_read=79370914 bytes_retransmit=0 bytes_invalid=0 send_seq=4299189 receive_seq=4299189 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996896 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547415 bytes_read=26020374 bytes_retransmit=9 bytes_invalid=0 send_seq=1835604 receive_seq=1835604 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999231 adj=120002178 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461412 bytes_read=4597769 bytes_retransmit=126 bytes_invalid=0 send_seq=243071 receive_seq=243071 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831742 adj=71833007 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000007 bytes_write=1789635 bytes_read=4725343 bytes_retransmit=284 bytes_invalid=0 send_seq=270044 receive_seq=270044 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999307 adj=50000514 sd_pos=29866 mcu_temp: temp=47.9 chamber_temp: temp=36.8 heater_bed: target=75 temp=61.2 pwm=1.000 sysload=0.85 cputime=133166.459 memavail=139696 print_time=239236.632 buffer_time=2.190 print_stall=1 extruder: target=180 temp=223.7 pwm=0.000
[INFO] 2025-08-03 20:58:16,034 [root] [gcode:respond_info:301] x_park = -104.5
[INFO] 2025-08-03 20:58:16,036 [root] [gcode:respond_info:301] y_park = 104.0
[INFO] 2025-08-03 20:58:16,069 [root] [homing:cmd_G28:343] [RUN_G28_Z] Start run_G28_Z(False)...
[INFO] 2025-08-03 20:58:16,070 [root] [homing:cmd_G28:343] [ENABLE_STEPS] Start enable_steps()...
[INFO] 2025-08-03 20:58:18,817 [root] [statistics:generate_stats:68] Stats 1707450.6: gcodein=0 mcu: mcu_awake=0.004 mcu_task_avg=0.000010 mcu_task_stddev=0.000006 bytes_write=235385192 bytes_read=79372034 bytes_retransmit=0 bytes_invalid=0 send_seq=4299219 receive_seq=4299219 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996898 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547517 bytes_read=26020713 bytes_retransmit=9 bytes_invalid=0 send_seq=1835613 receive_seq=1835613 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999227 adj=120002192 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461430 bytes_read=4597830 bytes_retransmit=126 bytes_invalid=0 send_seq=243074 receive_seq=243074 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831804 adj=71832578 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000007 bytes_write=1789653 bytes_read=4725404 bytes_retransmit=284 bytes_invalid=0 send_seq=270047 receive_seq=270047 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999302 adj=50000472 sd_pos=29866 mcu_temp: temp=48.3 chamber_temp: temp=36.8 heater_bed: target=75 temp=61.9 pwm=1.000 sysload=0.85 cputime=133166.795 memavail=140304 print_time=239239.250 buffer_time=1.806 print_stall=1 extruder: target=180 temp=218.8 pwm=0.000
[INFO] 2025-08-03 20:58:20,649 [root] [homing:cmd_G28:343] [DEBUG] G28_Z: Wait for Nozzle to cool down[180.00 -> 180.00]...
[INFO] 2025-08-03 20:58:20,650 [root] [homing:cmd_G28:343] [SET_FAN_SPEED] fan_name=fan, fan_spd=1.000000
[INFO] 2025-08-03 20:58:20,668 [root] [homing:cmd_G28:343] [SET_HOT_TEMPS] temp=180.00, wait=1, err=5.000000
[INFO] 2025-08-03 20:58:21,816 [root] [statistics:generate_stats:68] Stats 1707453.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000009 mcu_task_stddev=0.000006 bytes_write=235385485 bytes_read=79373134 bytes_retransmit=0 bytes_invalid=0 send_seq=4299242 receive_seq=4299242 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996898 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547632 bytes_read=26021044 bytes_retransmit=9 bytes_invalid=0 send_seq=1835623 receive_seq=1835623 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999222 adj=120002149 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461448 bytes_read=4597878 bytes_retransmit=126 bytes_invalid=0 send_seq=243077 receive_seq=243077 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831819 adj=71833833 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000007 bytes_write=1789671 bytes_read=4725452 bytes_retransmit=284 bytes_invalid=0 send_seq=270050 receive_seq=270050 retransmit_seq=265681 srtt=0.000 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999303 adj=50000434 sd_pos=29866 mcu_temp: temp=48.8 chamber_temp: temp=36.8 heater_bed: target=75 temp=62.6 pwm=1.000 sysload=0.86 cputime=133167.084 memavail=140652 print_time=239240.662 buffer_time=0.219 print_stall=1 extruder: target=180 temp=213.9 pwm=0.000
[INFO] 2025-08-03 20:58:24,817 [root] [statistics:generate_stats:68] Stats 1707456.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000009 mcu_task_stddev=0.000006 bytes_write=235385771 bytes_read=79374201 bytes_retransmit=0 bytes_invalid=0 send_seq=4299264 receive_seq=4299264 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996895 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547734 bytes_read=26021383 bytes_retransmit=9 bytes_invalid=0 send_seq=1835632 receive_seq=1835632 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999215 adj=120002125 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461466 bytes_read=4597939 bytes_retransmit=126 bytes_invalid=0 send_seq=243080 receive_seq=243080 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831809 adj=71834027 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000007 bytes_write=1789689 bytes_read=4725513 bytes_retransmit=284 bytes_invalid=0 send_seq=270053 receive_seq=270053 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999299 adj=50000486 sd_pos=29866 mcu_temp: temp=49.1 chamber_temp: temp=36.8 heater_bed: target=75 temp=63.3 pwm=1.000 sysload=0.86 cputime=133167.329 memavail=139712 print_time=239243.596 buffer_time=0.151 print_stall=1 extruder: target=180 temp=209.0 pwm=0.000
[INFO] 2025-08-03 20:58:27,818 [root] [statistics:generate_stats:68] Stats 1707459.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000008 mcu_task_stddev=0.000004 bytes_write=235386065 bytes_read=79375300 bytes_retransmit=0 bytes_invalid=0 send_seq=4299287 receive_seq=4299287 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996894 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547836 bytes_read=26021709 bytes_retransmit=9 bytes_invalid=0 send_seq=1835641 receive_seq=1835641 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999209 adj=120002191 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461484 bytes_read=4598000 bytes_retransmit=126 bytes_invalid=0 send_seq=243083 receive_seq=243083 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831855 adj=71833630 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000007 bytes_write=1789707 bytes_read=4725561 bytes_retransmit=284 bytes_invalid=0 send_seq=270056 receive_seq=270056 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999311 adj=50000521 sd_pos=29866 mcu_temp: temp=49.6 chamber_temp: temp=36.8 heater_bed: target=75 temp=64.0 pwm=1.000 sysload=0.79 cputime=133167.582 memavail=139688 print_time=239246.625 buffer_time=0.180 print_stall=1 extruder: target=180 temp=203.8 pwm=0.000
[INFO] 2025-08-03 20:58:30,820 [root] [statistics:generate_stats:68] Stats 1707462.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000008 mcu_task_stddev=0.000004 bytes_write=235386351 bytes_read=79376381 bytes_retransmit=0 bytes_invalid=0 send_seq=4299309 receive_seq=4299309 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996892 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96547938 bytes_read=26022048 bytes_retransmit=9 bytes_invalid=0 send_seq=1835650 receive_seq=1835650 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999203 adj=120002227 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461502 bytes_read=4598048 bytes_retransmit=126 bytes_invalid=0 send_seq=243086 receive_seq=243086 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831891 adj=71834399 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000008 bytes_write=1789725 bytes_read=4725622 bytes_retransmit=284 bytes_invalid=0 send_seq=270059 receive_seq=270059 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999317 adj=50000782 sd_pos=29866 mcu_temp: temp=49.9 chamber_temp: temp=36.8 heater_bed: target=75 temp=64.8 pwm=1.000 sysload=0.97 cputime=133167.834 memavail=140676 print_time=239249.662 buffer_time=0.215 print_stall=1 extruder: target=180 temp=198.3 pwm=0.000
[INFO] 2025-08-03 20:58:32,835 [root] [verify_heater:check_event:52] Heater heater_bed within range of 75.000
[INFO] 2025-08-03 20:58:33,820 [root] [statistics:generate_stats:68] Stats 1707465.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000008 mcu_task_stddev=0.000004 bytes_write=235386629 bytes_read=79377461 bytes_retransmit=0 bytes_invalid=0 send_seq=4299331 receive_seq=4299331 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996892 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96548040 bytes_read=26022387 bytes_retransmit=9 bytes_invalid=0 send_seq=1835659 receive_seq=1835659 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999198 adj=120002222 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461520 bytes_read=4598109 bytes_retransmit=126 bytes_invalid=0 send_seq=243089 receive_seq=243089 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831871 adj=71834471 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000008 bytes_write=1789743 bytes_read=4725683 bytes_retransmit=284 bytes_invalid=0 send_seq=270062 receive_seq=270062 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999311 adj=50000758 sd_pos=29866 mcu_temp: temp=50.1 chamber_temp: temp=36.8 heater_bed: target=75 temp=65.5 pwm=1.000 sysload=0.97 cputime=133168.093 memavail=139596 print_time=239252.690 buffer_time=0.244 print_stall=1 extruder: target=180 temp=192.7 pwm=0.000
[INFO] 2025-08-03 20:58:36,821 [root] [statistics:generate_stats:68] Stats 1707468.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000008 mcu_task_stddev=0.000004 bytes_write=235386923 bytes_read=79378560 bytes_retransmit=0 bytes_invalid=0 send_seq=4299354 receive_seq=4299354 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996891 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96548157 bytes_read=26022718 bytes_retransmit=9 bytes_invalid=0 send_seq=1835669 receive_seq=1835669 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999192 adj=120002205 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461538 bytes_read=4598157 bytes_retransmit=126 bytes_invalid=0 send_seq=243092 receive_seq=243092 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831820 adj=71833622 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000008 bytes_write=1789761 bytes_read=4725731 bytes_retransmit=284 bytes_invalid=0 send_seq=270065 receive_seq=270065 retransmit_seq=265681 srtt=0.000 rttvar=0.001 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999304 adj=50000541 sd_pos=29866 mcu_temp: temp=50.4 chamber_temp: temp=36.9 heater_bed: target=75 temp=66.2 pwm=1.000 sysload=0.89 cputime=133168.345 memavail=139740 print_time=239255.620 buffer_time=0.173 print_stall=1 extruder: target=180 temp=187.2 pwm=0.066
[INFO] 2025-08-03 20:58:39,372 [root] [homing:cmd_G28:343] [SET_FAN_SPEED] fan_name=fan, fan_spd=0.000000
[INFO] 2025-08-03 20:58:39,388 [root] [homing:cmd_G28:343] [SET_FAN_SPEED] fan_name=fan, fan_spd=0.000000
[INFO] 2025-08-03 20:58:39,400 [root] [homing:cmd_G28:343] [PRTOUCH_MOVE] Start Move, gcmd=G1 F2400 X115.567 Y114.094 Z0.000
[INFO] 2025-08-03 20:58:39,401 [root] [bed_mesh:move:235] bed_mesh fade complete: Current Z: 203.3900 fade_target: 0.0000
[INFO] 2025-08-03 20:58:39,821 [root] [statistics:generate_stats:68] Stats 1707471.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000008 mcu_task_stddev=0.000004 bytes_write=235388342 bytes_read=79379722 bytes_retransmit=0 bytes_invalid=0 send_seq=4299395 receive_seq=4299395 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996891 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96548290 bytes_read=26023067 bytes_retransmit=9 bytes_invalid=0 send_seq=1835680 receive_seq=1835680 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999188 adj=120002197 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461556 bytes_read=4598218 bytes_retransmit=126 bytes_invalid=0 send_seq=243095 receive_seq=243095 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831778 adj=71832886 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000009 bytes_write=1789779 bytes_read=4725792 bytes_retransmit=284 bytes_invalid=0 send_seq=270068 receive_seq=270068 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999308 adj=50000478 sd_pos=29866 mcu_temp: temp=50.6 chamber_temp: temp=36.9 heater_bed: target=75 temp=66.9 pwm=1.000 sysload=0.89 cputime=133168.730 memavail=139704 print_time=239268.572 buffer_time=10.125 print_stall=1 extruder: target=180 temp=183.8 pwm=0.135
[INFO] 2025-08-03 20:58:42,822 [root] [statistics:generate_stats:68] Stats 1707474.6: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000010 mcu_task_stddev=0.000007 bytes_write=235388620 bytes_read=79380817 bytes_retransmit=0 bytes_invalid=0 send_seq=4299417 receive_seq=4299417 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996890 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96548402 bytes_read=26023387 bytes_retransmit=9 bytes_invalid=0 send_seq=1835689 receive_seq=1835689 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999184 adj=120002319 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461574 bytes_read=4598279 bytes_retransmit=126 bytes_invalid=0 send_seq=243098 receive_seq=243098 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831759 adj=71833805 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000009 bytes_write=1789797 bytes_read=4725840 bytes_retransmit=284 bytes_invalid=0 send_seq=270071 receive_seq=270071 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999301 adj=50000658 sd_pos=29866 mcu_temp: temp=50.7 chamber_temp: temp=36.9 heater_bed: target=75 temp=67.6 pwm=1.000 sysload=1.06 cputime=133168.970 memavail=140020 print_time=239268.572 buffer_time=7.125 print_stall=1 extruder: target=180 temp=181.7 pwm=0.121
[INFO] 2025-08-03 20:58:45,825 [root] [statistics:generate_stats:68] Stats 1707477.7: gcodein=0 mcu: mcu_awake=0.003 mcu_task_avg=0.000009 mcu_task_stddev=0.000004 bytes_write=235388906 bytes_read=79381914 bytes_retransmit=0 bytes_invalid=0 send_seq=4299439 receive_seq=4299439 retransmit_seq=0 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119996888 nozzle_mcu: mcu_awake=0.001 mcu_task_avg=0.000006 mcu_task_stddev=0.000004 bytes_write=96548520 bytes_read=26023728 bytes_retransmit=9 bytes_invalid=0 send_seq=1835699 receive_seq=1835699 retransmit_seq=2 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=119999181 adj=120002310 leveling_mcu: mcu_awake=0.000 mcu_task_avg=0.000004 mcu_task_stddev=0.000003 bytes_write=1461592 bytes_read=4598327 bytes_retransmit=126 bytes_invalid=0 send_seq=243101 receive_seq=243101 retransmit_seq=235568 srtt=0.001 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=71831886 adj=71833735 rpi: mcu_awake=0.000 mcu_task_avg=0.000008 mcu_task_stddev=0.000007 bytes_write=1789815 bytes_read=4725901 bytes_retransmit=284 bytes_invalid=0 send_seq=270074 receive_seq=270074 retransmit_seq=265681 srtt=0.000 rttvar=0.000 rto=0.025 ready_bytes=0 stalled_bytes=0 freq=49999306 adj=50000633 sd_pos=29866 mcu_temp: temp=50.9 chamber_temp: temp=36.8 heater_bed: target=75 temp=68.2 pwm=1.000 sysload=1.06 cputime=133169.214 memavail=139636 print_time=239268.572 buffer_time=4.121 print_stall=1 extruder: target=180 temp=180.4 pwm=0.176
[INFO] 2025-08-03 20:58:48,175 [root] [webhooks:_handle_query:530] _handle_query objects/subscribe:{'webhooks': None, 'configfile': None, 'mcu': None, 'mcu nozzle_mcu': None, 'mcu leveling_mcu': None, 'mcu rpi': None, 'gcode_macro xyz_ready': None, 'gcode_macro _IF_HOME_Z': None, 'gcode_macro _IF_MOVE_XY': None, 'gcode_macro _HOME_X': None, 'gcode_macro _HOME_Y': None, 'gcode_macro _HOME_Z': None, 'gcode_macro PRINTER_PARAM': None, 'gcode_macro AUTOTUNE_SHAPERS': None, 'gcode_macro LOAD_MATERIAL_CLOSE_FAN2': None, 'gcode_macro LOAD_MATERIAL_RESTORE_FAN2': None, 'gcode_macro SET_E_MIN_CURRENT': None, 'gcode_macro RESTORE_E_CURRENT': None, 'gcode_macro LOAD_MATERIAL': None, 'gcode_macro QUIT_MATERIAL': None, 'gcode_macro Qmode': None, 'gcode_macro Qmode_exit': None, 'gcode_macro M204': None, 'gcode_macro M205': None, 'gcode_macro M106': None, 'gcode_macro M107': None, 'gcode_macro M141': None, 'gcode_macro M900': None, 'gcode_macro WAIT_TEMP_START': None, 'gcode_macro WAIT_TEMP_END': None, 'gcode_macro PRINT_CALIBRATION': None, 'gcode_macro FIRST_FLOOR_PAUSE_POSITION': None, 'gcode_macro ACCURATE_G28': None, 'gcode_macro START_PRINT': None, 'gcode_macro PRINT_PREPARED': None, 'gcode_macro PRINT_PREPARE_CLEAR': None, 'gcode_macro END_PRINT_POINT_WITHOUT_LIFTING': None, 'gcode_macro END_PRINT_POINT': None, 'gcode_macro END_PRINT': None, 'gcode_macro FIRST_FLOOR_PAUSE': None, 'gcode_macro FIRST_FLOOR_RESUME': None, 'gcode_macro PAUSE': None, 'gcode_macro INPUTSHAPER': None, 'gcode_macro BEDPID': None, 'gcode_macro TUNOFFINPUTSHAPER': None, 'gcode_macro RESUME': None, 'gcode_macro CANCEL_PRINT': None, 'gcode_macro G29': None, 'gcode_macro AAA_BedMesh': None, 'gcode_macro AAA_In': None, 'gcode_macro AAA_Out': None, 'gcode_move': None, 'print_stats': None, 'fan_feedback': None, 'custom_macro': None, 'idle_timeout': None, 'virtual_sdcard': None, 'heaters': None, 'temperature_sensor mcu_temp': None, 'temperature_sensor chamber_temp': None, 'temperature_fan chamber_fan': None, 'tmc2209 stepper_x': None, 'tmc2209 stepper_y': None, 'tmc2209 stepper_z': None, 'tmc2209 extruder': None, 'heater_bed': None, 'pause_resume': None, 'filament_switch_sensor filament_sensor': None, 'filament_switch_sensor filament_sensor_2': None, 'heater_fan hotend_fan': None, 'output_pin fan0': None, 'output_pin fan1': None, 'output_pin fan2': None, 'output_pin LED': None, 'probe': None, 'bed_mesh': None, 'display_status': None, 'exclude_object': None, 'motion_report': None, 'query_endstops': None, 'system_stats': None, 'manual_probe': None, 'toolhead': None, 'extruder': None}
[INFO] 2025-08-03 20:58:48,176 [root] [webhooks:_handle_query:552] _handle_query before complete.wait
[INFO] 2025-08-03 20:58:48,276 [root] [klippy:invoke_shutdown:299] +++++++++++++++invoke_shutdown
[ERROR] 2025-08-03 20:58:48,277 [root] [klippy:invoke_shutdown:300] Transition to shutdown state: Shutdown due to webhooks request
